[Solved] Cannot access boundbox of created nodes in custom ConsoleCommand
i was using the Unigine::Console::addCommand with Unigine::MakeCallback, to populate our scene with test objects.
Inside the callback, i do the following:
  Code:
  auto node = Unigine::World::loadNode("<path-to-our-node>.node");
    if (!node)
        return false;
    node->setWorldPosition(Unigine::Math::Vec3(position.x, position.y, position.z));
   auto boundBox = node->getWorldBoundBox();
the boundbox has now values like:
Callstack points to:
void Unigine::CustomApp::doUpdate()
Questions:
  1. I did not find any documented limitations - is there any?. It looks to me that loading a node is not supported at this point. Or the updating is not allowed.
  2. How can i achieve that an object is loaded and can be afterwards manipulated?
Thanks in advance,
Sascha
Hello Sascha,
What's inside this node? Anyway, try the following:
  • Change loadNode to loadNode(node, 0). This will exclude node from cache. Please, write back if this will work.
  • Update spatial tree with World::updateSpatial();
  • Check this case with 2.11 beta
If nothing helps please, build a test scene that we can debug on our side.
Thanks.
2 hours ago, morbid said:
Hello Sascha,
Thanks.
Hello morbid,
thanks for the response. The node contains a ObjectMeshStatic. Unfortunately the proposals did not work. I will set up and upload a sample project.
Regards.
Edited by sascha.schneider
Update
please check your private messages, i have send the example.
sascha.schneider
You are calculating bound from the NodeDummy, not the ObjectMeshStatic because In your Flagge.node the first object is:
<node type="NodeDummy" id="587780787" name="Flagge">
Since 2.11 NodeDummy objects have no bounds. Please, check the devlog here (Bounds Calculation Changes section):
So you need either to:
  • Remove the root dummy object and calculate bounds of the ObjectMeshStatic directly. In that case results will be: added object with bbox max = 0.07 0.10 5.00
    OR
  • Use Local Hierarchical Bounds (slower): auto box = node->getHierarchyBoundBox(); In that case results will be: added object with bbox max = 0.40 2.82 5.00
1 hour ago, silent said:
sascha.schneider
    OR
Hello Silent,
Thank you, for that clarification. Will try to rearrange the data.
Regards,
Sascha
  • sascha.schneider changed the title to [Solved] Cannot access boundbox of created nodes in custom ConsoleCommand
