[SOLVED] How to setup a working C# environment in linux ?
I'm an Unreal Engine and Unity developer and I want to have a look to Unigine
I'm a very new user of Unigine and I've lot a difficulties to setup a dev environnement on Linux.
I've read online docs
here
https://developer.unigine.com/en/docs/2.10/start/programmer
and here
https://developer.unigine.com/en/docs/2.10/code/csharp/application
and looked in the forum
But I found no answer to my question.
I created a new project with the following settings
- SDK: 2.10.0.2 entertainment evaluation version
- template: empty (VR is the only other choice, no "C# template" for me)
- API+IDE: C# (.net Core) (no other choice for C#)
I managed to setup VS Code to build the project (by adding some extensions for C++ and C#) , but I encountered the following errors when I tried to build using the "Run debug" task
  The framework 'Microsoft.NETCore.App', version '2.2.0' was not found.
After a search on google, I've successfully installed the Dotnet core 2.2.110 SDK using its install script (no package for that version on Arch Linux repos)
And I managed to build the project without error in the VS code terminal:
  Restore completed in 15,71 ms for /mnt/D/Projets/Unigine/first/first.csproj.
  first -> /mnt/D/Projets/Unigine/first/bin/first_x64d.dll
  CSPropertyGenerator started
  CSPropertyGenerator completed successfully in 0.42 seconds
I can run the project in the editor.
But I can not debug. Setting up break points in VS code does nothing.
How can I "link" the projet in the editor and the code in VS code ?
Is there a "common way" to build and run the project from the editor, or VS code , or both  (as we can have the "build" and "run" buttons in Unreal Engine) ?
Thanks for your answers
Edited by laurent.ongaro
typo
Hi Laurent,
To be able to debug the C# Project under Linux you need to configure launch.json file inside .vscode directory:
For example, for a simple new project it can look something like that:
   // Use IntelliSense to find out which attributes exist for C# debugging
   // Use hover for the description of the existing attributes
   // For further information visit https://github.com/OmniSharp/omnisharp-vscode/blob/master/debugger-launchjson.md
   "version": "0.2.0",
   "configurations": [
            "name": "Run Debug",
            "type": "coreclr",
            "request": "launch",
            "preLaunchTask": "build debug",
            "program": "${workspaceFolder}/bin/unigine_project_x64d.dll",
            "args": "-data_path ../ -console_command \"world_load unigine_project\"",
            "cwd": "${workspaceFolder}",
            "console": "internalConsole",
            "stopAtEntry": false,
            "name": "Run Release",
            "type": "coreclr",
            "preLaunchTask": "build release",
            "program": "${workspaceFolder}/bin/unigine_project_x64.dll",
            "args": [],
            "name": ".NET Core Attach",
            "type": "coreclr",
            "request": "attach",
            "processId": "${command:pickProcess}"
The main section here is args: you need to specify the parameter that engine will use to startup.
After that you can simply hit F5 in VS Code and your application should run.
Hello I tried to follow the above steps using Windows and VS Code
I am using a project created starting from component_samples
Steps I did:
1 replace the program name with csharp_component_samples_x64d.dll
2. create a new prelaunch task as "build debug" as it does not exist in the tasks.
3. I also changed the args to the .world I wanted to open as a consolle command in my case it was ".Create_And_Delete"
All worked and started  but there's no way I can actually debug it, it ignores breakpoints...
I am probably missing something...
thanks you for help
Fred
That's pretty strange. I was able to debug on my Linux machine (at least breakpoints worked as expected):
The only drawback I was found that if Engine grabs a cursor and breakpoint hits you will not be able to go back to the VS Code :) I guess it should be easy to fix in the future versions.
I will also check this behavior at my work PC on Monday.
Regarding ignored breakpoints while running from VS Code, it looks like you can adjust .csproj file and replace
<DebugType>full</DebugType>
with
<DebugType>portable</DebugType>
to make debugger work again.
Could you please verify if this helps?
YESS !!
that worked perfectly ! thanks !
  • silent changed the title to [SOLVED] How to setup a working C# environment in linux ?
