No "lib" sub-folder in the SDK folders, as indicated in the linux setup part of the doc
I've noticed the following point in the linux documentation https://developer.unigine.com/en/docs/2.10/code/environment/linux?rlang=cpp
You may also need to set the following environment variables:
  • Add to $LD_LIBRARY_PATH variable locations of the following directories: <UnigineSDK>/lib.
Re-login to make the changes in ~/.profile take effect.
but there is not "lib" sub-folder in the SDK folders
Edited by laurent.ongaro
Hi Laurent,
Thanks, we will update documentation and revise articles, since is pretty much outdated right now.
The lib folder is now gone and all the libraries are located in bin.
