dongju.jeong Posted April 13, 2020 Posted April 13, 2020 (edited) body's contactcallback function deosn't called during terrain contact. The options and masks were matched. dummy body Terrain Height after checking, I found the Callback function doesn't called when contact with another body. what is the ploblem? system is <-- cause of IG system, I made a separate physical body. //----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- + I checked that only the rigid body calls the callback function. dummy body can't use callback function?? and And even if the body type is set to RigidBody, does IG's CollisionVol Response work? Edited April 13, 2020 by dongju.jeong
morbid Posted April 14, 2020 Posted April 14, 2020 Hello, Dummy object is considered to be static and it will not have any contacts. So this behavior is okay. 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
