Question about landscape terrain coding
Can I create LandscapeTerrain purely procedural in C# or C++ ? Some kickstart direction where to look would be highly appreciated (maybe some short example code if it's not to much asked?).
Hi Janis
Try this unigine API doc
        aargh
1 hour ago, aargh said:
Hi Janis
        aargh
Im already madly diving into documentation, but I can't connect the dots. Its very complex hierarchy as it seems. Im sure some few code lines would kickstart me in right direction. I created the `ObjectLandscapeTerrain ` object in code, but I don't see how to pressed- how can I feed procedural texture to it etc. Pointing to lots of related docs randomly is not helpful at moment.
Edited by janis.taranda
Precision
Hello Janis,
C# component TerrainGenerator.cs contains a simple example of creating a landscape based on two textures: albedo and height. These textures are loaded from files, but you can create them procedurally. For default parameters, you must configure the component as in the attached screenshot.
TerrainGenerator.cs
  • Like 3
11 hours ago, karpych11 said:
Hello Janis,
Huge thanks!!!!
