[SOLVED] control Entity using ig manager
When an entity is first created through ig_manager, the function does not work in the same frame.
sample->getNode()->setWorldPosition(Math::Vec3(-4.62241, -6.44629, 12.84174));   // It works if it exists after the frame.
However, functions related to the IEntity class do not work even if after frame.
2.9 version
Edited by dongju.jeong
Hello dongju!
you need turn off interpolation for work with entity transformation directly without cigi.
IG::IEntity * sample = AppSystemLogic::ig_manager->getEntity(222);
sample->setType(200);
sample->setInterpolation(0); // <== turn off interpolation
sample->setCollision(1);
sample->setRotationEuler(Unigine::Math::vec3(89, 0, 0));
sample->setGeoPosition(AppSystemLogic::ig_manager->getConverter()->worldToGeodetic(Unigine::Math::Vec3(0, 3, 1500)));
thank you.
The problem was solved.
  • silent changed the title to [SOLVED] control Entity using ig manager
