marin.komendanovic Posted May 11, 2020 Posted May 11, 2020 Hello, you've made a pretty epic engine, anyhow I was playing with some samples and noticed that my GPU would make constant high pitched coil whine noise while running those samples. I never heard it so loud before, when playing some gpu intensive games for example. My cpu is Nvidia RTX 2060. Anyone else have similar side effect?
morbid Posted May 11, 2020 Posted May 11, 2020 Hi, this effect occurs very often when your GPU outputs a tremendous frame rate. Depends a lot on the particular device, by the way. You can enable VSync or use console command "render_max_fps 60/75/144 (choose your refresh rate)". Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
