jochen.wolfrum Posted July 23, 2011 Posted July 23, 2011 Hi Guys, i have a question for Reflection in Unigine. How is it possible to read out the name of a calling function. Here the Code in Java which i could really need in Unigine: StackTraceElement[] trace = new Throwable().getStackTrace(); int count = 0; int i = 0; int idxFunctionName = 2; int idxCallFktInfo = 3; String refFunctionName = ""; count = trace.length; for (i=1; i == (count -1); i++) { if (trace[i].getMethodName().toLowerCase() != "LogToFile".toLowerCase()) { idxFunctionName = i; idxCallFktInfo = idxFunctionName + 1; break; } } if (count > idxCallFktInfo) { String temp = trace[idxFunctionName].getClassName().toString() + ":" + trace[idxFunctionName].getMethodName().toString(); refFunctionName = temp; } else if (count > idxFunctionName) { String temp = trace[idxFunctionName].getClassName().toString() + ":" + trace[idxFunctionName].getMethodName().toString(); refFunctionName = temp; } return refFunctionName; Can someone tell me, how I can make the same in Ungine?
manguste Posted July 27, 2011 Posted July 27, 2011 Reflection is not possible. Unigine scripts have C++ like syntax, so neither Java nor C# functionality is relevant.
jochen.wolfrum Posted July 27, 2011 Author Posted July 27, 2011 I know that Unigine has C++ Syntax. I wrote the java.code as an example. I thoughed it was clear. But at least i know now that reflection is not possible, thx.
