davide445 Posted June 23, 2020 Posted June 23, 2020 (edited) Related to this problem I urgently need to work on an "old" 2.10 project to finalize a proposal. No special features inside, VFX and VR plugins. Creating a new project with new license under 2.11 and just copying inside the data directory, removing the old project .world files, starting the Editor give me these errors and exit. 15:10:17 Interpreter::restore_state(): bad magic 15:10:17 forloop(int i = 0; property.getNumParameters()) 15:10:17 core/systems/tracker/editor/tracker_editor.h:881: Interpreter::parse_extern_class_begin(): unknown "Property" class member "getNumParameters" 15:10:17 Editor::editor_load(): can't load "editor2/editor.usc" editor script 15:10:23 "Can't create importer ...../<PojectName>/<PojectName>_safety_new/data/vr_template/props/vive/fbxes/vive_pad.fbx" .... 15:10:23 "Can't create importer ...../<PojectName>/<PojectName>_safety_new/data/vr_template/props/vive/fbxes/vive_basestation.fbx" .... 15:10:23 "Can't create importer ...../<PojectName>/<PojectName>_safety_new/data/vr_template/props/teleport_point/fbxes/teleport_point.fbx" 15:10:23 "Can't create importer ...../<PojectName>/<PojectName>_safety_new/data/vr_template/props/oculus/fbxes/oculus_touch_right.fbx" 15:10:23 "Can't create importer ...../<PojectName>/<PojectName>_safety_new/data/vr_template/props/oculus/fbxes/oculus_touch_left.fbx" 15:10:23 "Can't create importer ...../<PojectName>/<PojectName>_safety_new/data/Assets/Asset1.fbx" 15:10:23 "Can't create importer ...../<PojectName>/<PojectName>_safety_new/data/Assets/Container.fbx" 15:10:23 "Can't create importer ...../<PojectName>/<PojectName>_safety_new/data/Assets/Asset2.fbx" Edited June 23, 2020 by davide445
silent Posted June 23, 2020 Posted June 23, 2020 Hi Davide, To upgrade from Entertainment to Community edition you need to click Upgrade available ribbon here: and choose the Community SDK to upgrade: If you have unpacked core / editor2 / scripts directories inside data, please delete them. Copying 2.10 content inside 2.11 project will not work. Also, please keep in mind that following migration is only affects content. If you have code written in C++ / C# / UnigineScript you need to migrate it manually according to the migration guide: https://developer.unigine.com/en/docs/2.11/upgrade/migration_api Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
davide445 Posted June 23, 2020 Author Posted June 23, 2020 @silent None of my old projects is tagged with "Upgrade available", all of them are tagged as "Inactive SDK" As from previous thread I understood this is the expected behavior due to the license change. Waiting to find a solution with Anna, as a quick solution I need migrate in some way some of the projects to the new SDK release and license. I have multiple activities I need to postpone or block due to this limitation.
silent Posted June 23, 2020 Posted June 23, 2020 Well, that's unexpected. Looks like a bug. If there is no option to do Other Actions -> Configure Project (and select the 2.11 SDK) you can do the following: Locate SDK installation path (check the Options -> Storage Path in SDK Browser); Copy usc_x64.exe from <SDK_2.11_Install_dir>/bin to <SDK_2.11_Install_dir>/utils/upgrade. Open terminal in <SDK_2.11_Install_dir>/utils/upgrade directory and execute command:usc_x64.exe upgrade.usc "C:/Path/to/Unigine project/data" where C:/Path/to/Unigine project/data is content from 2.10 SDK Create new project in Community 2.11 SDK with the same name as migrated Copy files from the data directory of migrated 2.10 content, but skip the *.ung files (core.ung, editor2.ung, scripts.ung). After that you should be able to launch migrated project. Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
