jaaaaa Posted July 15, 2020 Posted July 15, 2020 Hello Folks, I would be interested in experiences with testing and Unigine, especially for larger projects. What kind of toolchain do you use for continuous integration and how do you unit test? Interacting with the Unigine API often needs Unigine to be initialized which makes tests tedious. Do you use some kind of mocking? Do you test your rendered output? How do you compare test results and expected outputs? I would guess pixelwise comparison can be achieved seldomly. I'm new to both testing in C++ and Unigine and would appreciate any input on this topic. Kind regards
jaaaaa Posted July 21, 2020 Author Posted July 21, 2020 Maybe some insights from Unigine itself? Do you have some kind of Integration testing set up with Unigine? Could you share insights on how you test, what you test and what you don't test (automatically)? I'd appreciate any input. Kind regards
silent Posted July 22, 2020 Posted July 22, 2020 ipg_jallmenroeder We have automated test benches for the performance (checking the profiler values (CPU / GPU) and compare them each and every day) and critical CPU-side tasks (like filesystem, assets, bounds and so on). We don't use any automated graphics testing due to major rendering changes (that we can do very often) that forces us to regenerate the references screenshots very often. Also due to the difference in the GPU models / GPU drivers / OS / API absolutely the same scene can be rendered slightly differently (for example, TAA can jitter different pixels). So, it's pretty much hard to find the right metrics that will say that this generated picture has artifacts (compared to the reference one). Right now all the graphics are tested manually via samples or internal projects. The best approach (at least in theory) is to check the RAW G-Buffers instead, but there can be also some discrepancy across the different PC configurations. We didn't tried it yet, so I don't know if it will work or will produce the same results that final image comparison. 2 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Lales.Charles Posted December 2, 2020 Posted December 2, 2020 Good, got partially an answer ;-) Any update on this maybe? Kind regards, Charles
silent Posted December 3, 2020 Posted December 3, 2020 What kind of information are you looking for? As I already mentioned before, there is no simply way to automate the final rendering tests, but you can try to it on your side. You have full access to every rendering stage and GBuffer textures, so you can write a separate logic that would try to produce as stable screenshots as possible (with fixed cameras position, fixed object's positions and so on) and compare them after each update. If you will eventuall find a better way to do it - please let us know :) How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Lales.Charles Posted December 3, 2020 Posted December 3, 2020 Hi, Were just wondering if anything could have pop-up since summer. Thanks for feedback, and suggestion for focus on GBuffer textures. Kind regards, Charles
silent Posted December 3, 2020 Posted December 3, 2020 Oh, I see. Nothing new, I'm afraid :) How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
