Lales.Charles Posted July 16, 2020 Posted July 16, 2020 Dear support, This doc (maybe others as well) has wrong macro name, making a search on real one unsuccessful:https://developer.unigine.com/en/docs/2.11/api/library/common/logic/component_system/cpp/class.componentbase COMPONENT_INIT(function_name, order); COMPONENT_UPDATEASYNCTHREAD(function_name, order); COMPONENT_UPDATESYNCTHREAD(function_name, order); COMPONENT_UPDATE(function_name, order); COMPONENT_POSTUPDATE(function_name, order); COMPONENT_UPDATEPHYSICS(function_name, order); COMPONENT_SWAP(function_name, order); COMPONENT_SHUTDOWN(function_name, order); COMPONENT_DESTROYRENDERRESOURCES(function_name, order); Where in SDK 2.11 ComponentSystem.h: #define COMPONENT_INIT(NAME, ...) COMPONENT_METHOD(Init, NAME, ##__VA_ARGS__) #define COMPONENT_UPDATE_ASYNC_THREAD(NAME, ...) COMPONENT_METHOD(UpdateAsyncThread, NAME, ##__VA_ARGS__) #define COMPONENT_UPDATE_SYNC_THREAD(NAME, ...) COMPONENT_METHOD(UpdateSyncThread, NAME, ##__VA_ARGS__) #define COMPONENT_UPDATE(NAME, ...) COMPONENT_METHOD(Update, NAME, ##__VA_ARGS__) #define COMPONENT_POST_UPDATE(NAME, ...) COMPONENT_METHOD(PostUpdate, NAME, ##__VA_ARGS__) #define COMPONENT_UPDATE_PHYSICS(NAME, ...) COMPONENT_METHOD(UpdatePhysics, NAME, ##__VA_ARGS__) #define COMPONENT_SWAP(NAME, ...) COMPONENT_METHOD(Swap, NAME, ##__VA_ARGS__) #define COMPONENT_SHUTDOWN(NAME, ...) COMPONENT_METHOD(Shutdown, NAME, ##__VA_ARGS__) #define COMPONENT_DESTROY_RENDER_RESOURCES(NAME, ...) COMPONENT_METHOD(DestroyRenderResources, NAME, ##__VA_ARGS__) Typically a search on "COMPONENT_POST_UPDATE" gives no result, whereas COMPONENT_POSTUPDATE does. It's not really important, simply annoying for new dev trying to find out how to implement components.. Kind regards, Charles 1
morbid Posted July 16, 2020 Posted July 16, 2020 Hi Charles, Thank you very much for reporting. Our documentation team will fix this. Regards, Vsevolod How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
