[SOLVED] Trouble with Physics Intersections
Does anyone have a working example of physics intersections? I can get World Intersections to work, which detect things such as ObjectMeshClusters. However I can not for the life of me get an Object to return from my physics intersection. I can not find any working examples in the documents either. I have collision & intersection flags on my objects set. My objects also have a rigid body shape. They are ObjectMeshStatic class. Can anyone nudge me in the right direction
I have tried about a hundred different ways to re-write my snippet and ultimately, I get no Object return from my intersection.
You can try using the attached component. I used two objects with Physics Intersection flags enabled. If the intersection is successful, the object name and the intersection point are displayed.
PhysicsIntersection.cs
Thank you thank you so much. I'm not a fan of asking FOR code, but I've been tearing my hair out over this simple script.
Edited by find_me
  • morbid changed the title to [SOLVED] Trouble with Physics Intersections
