morbid Posted August 18, 2020 Posted August 18, 2020 Thanks everyone for the provided feedback! The latest update includes a lot of bugfixes alongside with small, but handy improvements. SDK and Add-Ons are already hit the production server, Demos are on their way! Improvements Up to 4 times import speed improvement for the LandscapeTerrain. Microprofile now shows synchronization points for Syncker plugin Better serialization for Curve2d (Curve2d::saveState/restoreState) Syncker API extended: added methods for user messages bufferization Fixed issues UnigineEditor Geometry is partially ignored in some FBX files on the import stage LandscapeTerrain brushes windows appears to be empty after docking it to the editor interface Texture preview in the material widget now have correct size Engine Engine ignores runtime links if the asset file was removed Enabling Vsync with Linux causes engine to render empty scene Planar reflections artifacts with dynamic reflections enabled C# plugins crashes engine on the startup AppVarjo renders black screen AppVarjo camera randomly shakes in some cases Engine can’t correctly load guids.db from a package (archive) UnigineScript cache loading not working Tag <extern_plugins> is ignored in the default.boot configuration file Engine window loses focus when starting with AppVive plugin Syncker plugin asynchronous mode not working properly Incorrect particle system synchronization Demos Reconfigured clouds material in the Procedural City Generation demo. Fixed crash for C# API/Widgets/WidgetWindows sample Fixed missing UI in C# API/Widgets/WidgetDialog sample Extra slaves mode support added for Syncker Demo Fixed Oil Refinery demo crash with OpenGL API Released Fox Hole and Procedural City Generation demos Known Issues Main WPF sample crashes on startup (OpenGL only) How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
morbid Posted August 18, 2020 Author Posted August 18, 2020 Reserved How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
silent Posted August 19, 2020 Posted August 19, 2020 Community SDK is now also uploaded to the Baidu Cloud: Windows: https://pan.baidu.com/s/1au0P3ew8PKaOpA-5tbdjvg (access code: pipj) Linux: https://pan.baidu.com/s/139aLa12tUE_l_NVmerWFbg (access code: etrs) How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
