Catsasin4401 Posted August 19, 2020 Posted August 19, 2020 Hi every one I have a problem I followed the tutorial on YouTube about Physics And then when I change Body type to water it noting happen and turn back to none. I can change to another type but I want to use water type.
morbid Posted August 19, 2020 Posted August 19, 2020 Hello, Do you see any errors in the console? I assume you tried to add WaterBody to the WaterGlobal object. This body type can be applied to WaterMesh and Dynamic Mesh only. Please check this. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Catsasin4401 Posted August 19, 2020 Author Posted August 19, 2020 10 minutes ago, morbid said: Hello, Do you see any errors in the console? I assume you tried to add WaterBody to the WaterGlobal object. This body type can be applied to WaterMesh and Dynamic Mesh only. Please check this. Thanks!
morbid Posted August 19, 2020 Posted August 19, 2020 So the error says you can't create BodyWater for the WaterGlobal object, right? :) As I told you before, this type of body can be assigned for WaterMesh only or DynamicMesh. If you're looking for a way to add physics to the Global Water try Physical Water node. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Catsasin4401 Posted August 19, 2020 Author Posted August 19, 2020 3 hours ago, morbid said: So the error says you can't create BodyWater for the WaterGlobal object, right? :) As I told you before, this type of body can be assigned for WaterMesh only or DynamicMesh. If you're looking for a way to add physics to the Global Water try Physical Water node.
morbid Posted August 20, 2020 Posted August 20, 2020 It works only for the plane. I see that the docs doesn't mention it in straightforward way, it says that physical water can be created only for two-dimensional grid. So, please use plane only. Make sure that the grid is dense enough. Thanks. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
