Post-processing material parameter
hi,
I would like to know if it is possible to set a parameter for post-process material via C++ API.
                  Unigine::Render::setPostMaterials("post_hblur_gauss");
      // like  Uniigine::Render::setPostMaterialParam("Radius",2.2);
thanks
Hey Michal,
this thread should help you out:
You can find the .basemat-file in your sdk installation: data/core/materials/default/post/post_hblur_gauss.basemat
You need to inherit it and change the parameter just like in the linked thread.
Best regards
Dear @michal,
Set post process material in Editor. Or you may set it using C++ api.
In AppWorldLogic::update. Just a simple step like this.
    const char* stringMaterial = Render::getPostMaterials();
    MaterialPtr material = Materials::findMaterial(stringMaterial);
    rTimeThatGoesForever += Game::getIFps();
    float fValue = sin(rTimeThatGoesForever);
    material->setParameterFloat("radius", fValue);
This is just an example. Actually, the string returned will be combined one separated with comma. So you need to separate the material names and use them.
Rohit
On 8/21/2020 at 5:44 PM, rohit.gonsalves said:
Dear @michal,
Rohit
yes this exactly occurred to me first, when I didn't see the change so I thought
I'm going for it wrong. Now I tried to use "post_filter_sobel" instead of "post_hblur_gauss" and the scale parameter and the material is really changing.
thanks
