recursion in hierarchy
class Node {
string name;
Node child[];
Node(string aName){name=aName;}
void saveNode(Node node) {
log.message("save node [%s] children count: [%i]\n",node.name,node.child.size());
foreach(Node n; node.child)
	saveNode(n);
int init() {
Node root = new Node("zero");
Node one = new Node("one");
Node two = new Node("two");
root.child.append(1,one);
one.child.append(2,two);
root.child.append(3,new Node("three"));
saveNode(root);
This code crashes application without any error message.
Log:
13:01:15 Loading "worlds/vars.world" 186ms
13:01:15 save node [zero] children count: [2]
13:01:15 save node [one] children count: [1]
13:01:15 save node [two] children count: [0]
The same behavior with vector.
Thank you. Recursion bug is fixed.
As temporary solution you can use vector array with for/forloop cycle instead of foreach.
save node [three] children count: [0]
  • 1 month later...
I still get the same error in build of Unigine-20100907-src.. (
The bugfix will be incorporated into the next SDK update.
