SaltyWeevil Posted October 18, 2020 Posted October 18, 2020 (edited) Hi , I am trying to make a space ship controller and am kinda lost on how to add force to a node. Either i am making a silly mistake or I have lost my common sense :( . I have implemented a Component which adds force to the parent rigid body with respect to the node . I add it as a property to a child dummy node of the ship . The problem is . Its not working as i expected it work. The direction is not updating in the child nodes . Please help I have attached the source file for adding the force . My setup is simple . i have a main object with rigid body and multiple child dummy nodes with the thruster component for different thruster (yaw, pitch, roll .. etc) . i control them by enabling and disabling the property when given input key pressed. Thruster.cpp Thruster.h Edited October 18, 2020 by SaltyWeevil
SaltyWeevil Posted October 18, 2020 Author Posted October 18, 2020 Found the solution at last . it works as expected now . My bad . I missed the addWorldForce. I tried it with applying the force using world transform and it just worked . The updated files for thrusters is attached. Thruster.cpp Thruster.h 1
