Cameras in IG - syncker_channels section of ig_config.xml
Dear UNG team,
You introduce in 2.12 a way to declare in the configuration file the desired view for each slave and specify if it is affected by the syncker’s projections.
<syncker_channels>
	<channel syncker_name="center_view" view_id="0" use_syncker_projection="1"/>
	<channel syncker_name="left_view" view_id="0" use_syncker_projection="1"/>
	<channel syncker_name="ground_cam" view_id="1" use_syncker_projection="0"/>
</syncker_channels>
You mentioned this settings only in migration to 2.12:
https://developer.unigine.com/en/docs/2.12/upgrade/migration_api#ig_changes
Maybe it make sens to add it to standard documentation, or?
Kind regards,
Charles
Hi Charles,
Must have slipped out... sorry for the inconvenience caused. We'll surely update the Docs!
Thank you for pointing that out!
