scopic Posted December 3, 2020 Posted December 3, 2020 (edited) Hello, Please see the included GIF which that demonstrates the issue. Reflections on the floor seem to be quite large and not aligning with the room corners despite the fact that box env probe dimensions are set to match the size of the room. I use Dynamic type but baked one has same issue. I also tried sphere projection shape and it seems that adjusting the Parallax slider has absolutely no visible effect, which is also weird. In this video from your YouTube channel it seems that with box projection shape reflections on the floor are perfectly aligned with the room after tweaking the box size and this is not what I'm seeing here. Could you suggest what might be causing this? Thanks! Edited December 3, 2020 by scopic
silent Posted December 4, 2020 Posted December 4, 2020 scopic You can also download and install Art Samples demo to see how to configure the environment probes. Is there any chance that ground surface is using alpha blend material? In that case reflections from the environment probe will not match. Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
scopic Posted December 4, 2020 Author Posted December 4, 2020 Oh, that was it, disabling alpha blend on it did the job, thanks. Is there any tricks that would make reflections work correctly with transparent materials like glass on windows? Or are we forced to use performance-intensive planar reflections in this case? Thanks for helping out.
silent Posted December 4, 2020 Posted December 4, 2020 I'm afraid right now only the planar reflections can provide good results for the alpha blend materials. 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
