cast nodeptr
dynamic_cast<ObjectMeshSkinned*>(dynamic_cast<NodeReference*>(World::getNodeByName("Hand_rigged").get())->getReference().get());
When using dynamic_cast, is it correct for objects like NodePtr to use .get()?
and Among the functions of the node class, getNode() disappeared and only getNode(int id) remained.
Is it used like ptr->getNode(ptr->getID())?  for getNode().
Edited by dongju.jeong
Hello!
no. we strongly advise against using raw pointers.
in addition, we recommend checking that the nodes exist. this will help you find the error immediately if some node changes in the editor, not as you expected.
auto node_hang_rigged  = World::getNodeByName("Hand_rigged");
if (!node_hang_rigged)
    Log::error("can`t find 'Hang_rigged' node in world!\n");
    return; // or do smth else
auto ref_hang_rigged = checked_ptr_cast<NodeReference>(node_hang_rigged)
    Log::error("node 'Hang_rigged' in not NodeReference\n");
auto mesh_hang_rigged = checked_ptr_cast<ObjectMeshSkinned>(ref_hang_rigged->getReference())
    Log::error("reference inside 'Hang_rigged' in not ObjectMeshSkinned\n");
// ... do smth with mesh_hang_rigged
  • Like 2
