mathias.schreiter Posted August 16, 2011 Posted August 16, 2011 Hello Can you add a little toutorial to create a Car ? If I use the "sunspension" Joint my tire always roll in any axes... I don´t understud the way to freeze the rotation of the axes. Thank you
mathias.schreiter Posted August 17, 2011 Author Posted August 17, 2011 I´m Sorry... I resolved this problem (wrong mass setup.. ) Anyway I don´t undertund the right workfolw to create a simple veicle whit the control, this is very important because we are looking for a little race car game
manguste Posted August 18, 2011 Posted August 18, 2011 Have you looked at the Passage demo and its source code? This demo could definitely shed some light :) There you can find a car (it is one of the switchable players) under "flurry" name. Controls handling is also implemented there.
mathias.schreiter Posted August 18, 2011 Author Posted August 18, 2011 Hello manguste no I have an error message if I try to open this demo. joint.setCurrentLineraDistance(0.0f); demos/passage/flurry/flurry_player.h:99 Interpreter::parse_extern_class_begin(): unknown "JointWheel"class member "setCurrentLinearDistance" Also I find this code void update() { float ifps = engine.game.getIFps(); float torque = 0.0f; if(engine.controls.getState(CONTROLS_STATE_FORWARD) || engine.controls.getState(CONTROLS_STATE_TURN_UP)) { velocity = max(velocity,0); velocity += ifps * 15.0f; torque = 50.0f; } else if(engine.controls.getState(CONTROLS_STATE_BACKWARD) || engine.controls.getState(CONTROLS_STATE_TURN_DOWN)) { velocity = min(velocity,0); velocity -= ifps * 15.0f; torque = 50.0f; } else { velocity *= exp(-ifps); } velocity = clamp(velocity,-90.0f,90.0f); if(engine.controls.getState(CONTROLS_STATE_MOVE_LEFT) || engine.controls.getState(CONTROLS_STATE_TURN_LEFT)) { angle += ifps * 100.0f; } else if(engine.controls.getState(CONTROLS_STATE_MOVE_RIGHT) || engine.controls.getState(CONTROLS_STATE_TURN_RIGHT)) { angle -= ifps * 100.0f; } else { if(abs(angle) < 0.25f) angle = 0.0f; else angle -= sign(angle) * ifps * 45.0f; } angle = clamp(angle,-40.0f,40.0f); float base = 3.3f; float width = 3.0f; float angle_0 = angle; float angle_1 = angle; if(abs(angle) > EPSILON) { float radius = base / tan(angle * DEG2RAD); angle_0 = atan(base / (radius + width / 2.0f)) * RAD2DEG; angle_1 = atan(base / (radius - width / 2.0f)) * RAD2DEG; } joints[2].setAngularVelocity(velocity); joints[3].setAngularVelocity(velocity); joints[2].setAngularTorque(torque); joints[3].setAngularTorque(torque); joints[0].setAxis10(rotateZ(angle_0) * vec3(0.0f,1.0f,0.0f)); joints[1].setAxis10(rotateZ(angle_1) * vec3(0.0f,1.0f,0.0f)); if(engine.controls.getState(CONTROLS_STATE_USE)) { joints[0].setAngularDamping(20000.0f); joints[1].setAngularDamping(20000.0f); joints[2].setAngularDamping(20000.0f); joints[3].setAngularDamping(20000.0f); velocity = 0.0f; } else { joints[0].setAngularDamping(0.0f); joints[1].setAngularDamping(0.0f); joints[2].setAngularDamping(0.0f); joints[3].setAngularDamping(0.0f); } } }; I Dont undestud the way to associate my wheels to the kayboard direction Like thiss : if(engine.controls.getState(CONTROLS_STATE_FORWARD) || engine.controls.getState(CONTROLS_STATE_TURN_UP)) { velocity = max(velocity,0); velocity += ifps * 15.0f; torque = 50.0f; } else if(engine.controls.getState(CONTROLS_STATE_BACKWARD) || engine.controls.getState(CONTROLS_STATE_TURN_DOWN)) { velocity = min(velocity,0); velocity -= ifps * 15.0f; torque = 50.0f; I´m sorry but Im a 3D Artist and not a programmer. i Need to create this simple control to move the car and go on on the next step. Tenks for the Reply
manguste Posted August 19, 2011 Posted August 19, 2011 I have an error message if I try to open this demo. The demo will work in the next update. I Dont undestud the way to associate my wheels to the kayboard direction Like thiss : Take a look at Controls class, there you find description of all states of controls. Handling input can be done only via scripting, I'm afraid. Good news is you can use samples as templates; they do not require much modification, because controls are already handled there. You can use the following: * JointSuspension to create ray-cast wheels (see data/samples/physics/car_00) or * JointWheel for proper physical wheels (see data/samples/physics/car_02, which basically does the same as in code snippet above).
cem.orsel Posted July 11, 2014 Posted July 11, 2014 Manguste you said JointSuspension is ray-cast wheel and JointWheel is physical wheel. Is that true or is it the other way around? It is recommended in the documentations to assign rigid bodies to suspension joints, but dummy bodies to wheel joints. That gave me the impression that suspension joint is the one with the physical calculations.
silent Posted July 11, 2014 Posted July 11, 2014 Hi, Sorry, but we have a mistake in documetation about JoinWheel and dummy bodies. We will fix it asap. You should use rigid bodies with JointWheel. Also, JointWheel is a ray-cast wheel and JointSuspention is a physics wheel. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
elvieness Posted July 16, 2014 Posted July 16, 2014 Hi, Documentation on the JointWheel class has been fixed. https://developer.unigine.com/en/docs/1.0/scripting/library/physics/class.jointwheel#intro
