[SOLVED] How to convert tangent,normal and binormal vectors into a quaternion
I want to create a ObjectDynamic which uses the deferred pass from the built in mesh base material.
The vertex shader in core\shaders\mesh\common\vertex.h requires the tangent space to be encoded as quaternion.
How can I produce such a quaternion? I wonder if a function exists which does this job for me, either in UUSL or inside the C#/C++ Mathlib or in Unigine Script.
Many thanks
Helmut
Hello sweetluna,
thank you very much, I will try that.
If I'm understanding the docs correctly the normals will be autogenerated as well - which in theory could become an issue, because they are provided by the content creation tool. Anyways, the ObjectMeshDynamic is a very good point to start.
Best regards
Helmut
  • bmyagkov changed the title to [SOLVED] How to convert tangent,normal and binormal vectors into a quaternion
