Rotating a node in World Coordinates?
Hi all!
I'm new to Unigine, have some experience with Unity/Unreal/Godot, which is why this question is potentially embarrassing!
In following along the C# Components video, I wrote my own rotating object script just to get a feel for the scripting in Unigine. However, I decided I want to make a spotlight like object with a light that is angled and rotate it in World space. I have it angled like this:
spotlight_example.thumb.png.9ae7e31099899fc34946cd33b544e0fd.png"
I tried using both node.Rotate and node.WorldRotate, but no matter what, the result is the same, and the spotlight only rotates around the local z axis, rather than the World z axis.
Is there something obvious I'm missing? This is my code:
using System;
using System.Collections;
using Unigine;
[Component(PropertyGuid = "28521a6c93ad52dbe2a26a7edb6a8fc5e05dbe60")]
public class SpinnySpinny : Component
	public float rotation_speed = 100.0f;
	private void Init()
		// write here code to be called on component initialization
		Log.Message("Name of node = " + node.Name + "\n");
	private void Update()
		// Rotate the node
		node.WorldRotate(0, 0, rotation_speed * Game.IFps);
Thank you any responses!
The node.rotate and node.worldRotate methods perform the following transformations:
node.SetRotation(node.GetRotation() * new quat(0.0f, 0.0f, rotation_speed * Game.IFps));
and
node.SetWorldRotation(node.GetWorldRotation() * new quat(0.0f, 0.0f, rotation_speed * Game.IFps));
In these two cases, we rotate the object around its Z axis, and the only difference is whether the transformation of the parent node is taken into account or not.
In your case, you need to rotate the node around its non-basis axis in world space. To do this, you can use the following:
quat rot = node.GetWorldRotation();
rot = new quat(0.0f, 0.0f, rotation_speed * Game.IFps) * rot;
node.SetWorldRotation(rot);
  • Like 3
  • Thanks 1
Thank you for the answer and explanation! That worked like a charm!
Edited by JeremyG
  • 2 years later...
