syncker display's Width,Height
Even if the use_syncker_projections option is set to 0, does the fov value change in the actual viewport due to the width, height,Pos Y of the display parameter in the syncker?
Edited by dongju.jeong
if use_syncker_projections = 0 then syncker settings are not applied.
  • Thanks 1
If "use_syncker_projections = 1", is the fov setting of the camera in the editor or code ignored?
yes, the FOV settings will be ignored because the FOV taken from the width-heigth settings in the syncker configurator.
  • Thanks 1
