romain.janil Posted September 6, 2021 Posted September 6, 2021 HI, I'm using some custom landuse I've generated (geotif no compression 20 indexed colors 2.5mppx, no nodata transparency) but for some reasons some extracted tags (ie: indexed color from 9 to 9) produce bad results (pixel bombing everywhere): for example highly sloped cliffs here index color 9 (purple color) generate some mask white values whre supposed to but also a bit everywhere. Of course those pixels are not like that in source data. Same thing if I use the rgb values directly not the index. Some other tags generate good results. Any idea what's causing this or if it's a bug ?
bmyagkov Posted September 7, 2021 Posted September 7, 2021 Hello! Romain, to be honest it looks like a bug to me. And the problem now is that there isn't much you can do simply adjusting any settings. I believe the behavior you see happens due to mask blending, those "pixel bombing" must show the differences between colors where they overlap. We need to have a closer look on this, could you be so kind and share sources together with the configured ".sworm" project? Until we fix this internally, I recommend you to create and use an individual mask for those problem areas instead of one common mask for the whole area. Thanks
romain.janil Posted September 7, 2021 Author Posted September 7, 2021 Hi, I tried to identify the source of the problem a bit further: maybe it's to do with indexed colors somehow overlapping as you said (but different colors changes nothing...) HOWEVER, I tried exact same data source with a different file name - instead of iterating tests on the same file- and now results are OK, at least on this layer. So I think this is more a cache related problem (the weird thing is that I deleted lmaps and sandworm cache everytime I've iterated on the same file, only using another file worked... have a good day
romain.janil Posted September 8, 2021 Author Posted September 8, 2021 Hi, a little update on that subject: found out straight R8 only rasters don't seem to be supported unfortunately (I've made an FME process to export each land use palette keys trough individual rasters and wanted to save some disk space hence Red8 format) documentation says R8/16/32f are supported but they import as void data in sandworm. Had to coerce the data to RGBA8 (so lots of unnecessary data) for my individual masks to load and generate masks correctly (with color tagging as single band doesn't seem to work either). i'll try soon to combine the palette entries to RGBA bands and see if it's working with sandworm (again to save some space) and keep to update this thread. :)
bmyagkov Posted September 9, 2021 Posted September 9, 2021 Hello! 18 hours ago, romain.janil said: found out straight R8 only rasters don't seem to be supported unfortunately We have tested behavior on several 8-bit masks and unfortunately the problem is not reproduced on our side yet. Romain, could you make a simple sample for us using exactly your mask within configured .sworm project? Heights and albedo data are not needed, we will use TMS instead. Thanks!
romain.janil Posted September 9, 2021 Author Posted September 9, 2021 (edited) HI, here's a Red8 version which won't load correctly in sandworm (and FME settings used Note that values are already in the 0 255 range, and that there's only one band. And a mask in the archive. cliff_LU_R8.rar Edited September 9, 2021 by romain.janil
bmyagkov Posted September 9, 2021 Posted September 9, 2021 Thanks for shared assets, we already tested It and mask are looks good to me. Does we are missing something?
romain.janil Posted September 9, 2021 Author Posted September 9, 2021 well that's really odd indeed. Here preview is empty (and generated mask also) and so
romain.janil Posted September 9, 2021 Author Posted September 9, 2021 or when I create a new sandworm project with just this mask. I don't get what's going on
bmyagkov Posted September 9, 2021 Posted September 9, 2021 This is reminds me an one old issue which is already has been fixed in actual release. What is yours SDK version?
romain.janil Posted September 9, 2021 Author Posted September 9, 2021 it's 2.14.1.0, It think I missed latest hotfix fixes this problem. I'll test same data with latest version asap and let you know!
bmyagkov Posted September 9, 2021 Posted September 9, 2021 You can also check for the system messages in the console window after adding a mask to the project. If the asset has any problems, warnings are usually displayed here. To open it switch to Editor and select Windows -> Console from main menu.
romain.janil Posted September 9, 2021 Author Posted September 9, 2021 GdalTileAccessor: can't fetch raster data from dataset(cliff_LU_R8.tif).
bmyagkov Posted September 9, 2021 Posted September 9, 2021 39 minutes ago, romain.janil said: GdalTileAccessor: can't fetch raster data from dataset(cliff_LU_R8.tif). Romain, indeed as well as many other fixes this one has been fixed in most recent update 2.14.1.1 hotfix Besides the fixes, there were also useful improvements too, so I highly recommend you update. Thanks
romain.janil Posted September 13, 2021 Author Posted September 13, 2021 Hi, little update, all issues gone with latest hotfix update indeed. :) Have some suggestions to improve sandworm tool hower, I'll make another thread. Have a good day 2
bmyagkov Posted September 13, 2021 Posted September 13, 2021 1 hour ago, romain.janil said: Have some suggestions to improve sandworm tool hower, I'll make another thread. We will be glad to hear your suggestions Thanks!
