3danimation Posted September 9, 2021 Posted September 9, 2021 HI Please help me. I followed the tutorial to add a gizmo to the project in C++ i have tried several times and i get the gizmo to show up but the rotate does not work, the translate does not work nor does the scale.. but the gizmo itself is showing please help me if u can post the correct code in the reply and where to add it i would appreciate it.. also how do i remove the system menu when i press ESCAPE
silent Posted September 9, 2021 Posted September 9, 2021 3danimation What do you mean by gizmo code is not working? Can you show us your code and results that you are getting? What exact do you want to achieve? Quote also how do i remove the system menu when i press ESCAPE That can be disabled by modifying the start-up engine parameters: your_app.exe -extern_define MENU_USER Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
