Nodes created in editor get random z-scale value with double-precision
I've reported a bug here https://developer.unigine.com/forum/topic/666-objectwatermesh-reflection-bug/, and frustum said don't use scale on WorldLight, I'm absolutely sure that I never set the scale on worldLight, the scale was random, try this in double precision engine:
  1. load the world from above post
  2. select lightword object, and click x icon besides the scale value, reset scale to one, save the world
  3. reload the world, the z-scale value still not 1, it will become a random value(everytime reset scale and reload get different value)
it seems this bug only happened when load old world, if create a new world, add a lightworld, this will not happen.
it also happened when add NodeDummy into the old world, only z-scale get's random value.
Thanks. The patch is:
source/engine/world/Editor.cpp:952
int Editor::saveTransform(Xml *xml,const Mat4 &transform) const {
#ifdef USE_DOUBLE
	double data[16];
	data[0] = transform.m00; data[4] = transform.m01; data[8] = transform.m02;  data[12] = transform.m03;
	data[1] = transform.m10; data[5] = transform.m11; data[9] = transform.m12;  data[13] = transform.m13;
	data[2] = transform.m20; data[6] = transform.m21; data[10] = transform.m22; data[14] = transform.m23;
	data[3] = 0.0;       	data[7] = 0.0;       	data[11] = 0.0;       	data[15] = 1.0;
	return xml->setDoubleArrayData(data,16);
#else
	return xml->setFloatArrayData(transform,16);
#endif
