robert.walters Posted October 7, 2021 Posted October 7, 2021 I need to read when a specific joystick button is pressed. When the button is pressed I will make changes to a IG Entity. I have tried to create a joystick directly in the C++ api but without an example the syntax has me stumped. I have imported the ungine script example and that works, however, I need to use the button press to manipulate entities on the IG side in C++. I have tried the following in C++ to get the value of the updating script variable but it never changes. First here is the unigine script direct from the sample with the addition of a new variable for a specific button that I will try to read into the C++ side. #include <core/scripts/samples.h> using Unigine::Samples; #ifdef HAS_JOYSTICK /* */ Info info; ControlsJoystick joystick; /* */ int init() { createInterface("samples/controls/joystick_00.world"); engine.render.setShadowDistance(100.0f); setDescription("ControlsJoystick"); info = new Info(); joystick = new ControlsJoystick(0); joystick.updateEvents(); //int b1state = 2; return 1; } /* */ int update() { string str; joystick.updateEvents(); if(joystick.isAvailable()) { str = joystick.getName() + "\n"; str += format("\nAxes %d:\n",joystick.getNumAxes()); forloop(int i = 0; joystick.getNumAxes()) { str += format("%s:\t%5.2f\n",joystick.getAxisName(i),joystick.getAxis(i)); } str += format("\nPovs %d:\n",joystick.getNumPovs()); forloop(int i = 0; joystick.getNumPovs()) { str += format("%s:\t%d\n",joystick.getPovName(i),joystick.getPov(i)); } str += format("\nButtons %d:\n",joystick.getNumButtons()); forloop(int i = 0; joystick.getNumButtons()) { str += format("%d ",joystick.getButton(i)); } int b1state = joystick.getButton(0); str +=format("button 1 state: %i\n",b1state); } else { str = "Not available"; } info.set(str); return 1; } #else /* */ int init() { createInterface("samples/controls/joystick_00.world"); engine.render.setShadowDistance(100.0f); setDescription("This binary is built without ControlsJoystick support"); return 1; } #endif Next on the C++ side: #include <UnigineInterpreter.h> Interpreter* interp; int AppSystemLogic::init() { ... interp->get(); ... } int AppSystemLogic::update() { ... Log::message("b1 state from script export is %i\n",interp->getExternVariable("b1state")); ... } It always returns 0 even when I see the user interface change to 1 in the world window from the script update. Thanks for the help.
karpych11 Posted October 8, 2021 Posted October 8, 2021 Hello, I made the same example for C++. Also added messages for button 0 when pressed and released. AppSystemLogic.cpp AppSystemLogic.h 1
