HarpSeal1 Posted September 7, 2011 Posted September 7, 2011 Hello everyone, I installed the Unigine tools on a workstation today, after 1 successful mesh export Max 2012 will now immediately crash. Even exporting a simple box causes max to crash. I tried a simple reboot and reinstall of the tools. Are there any known issues or workarounds? In the meantime I'll try removing any trace of unigine tools and reinstall them. Thanks a lot!
HarpSeal1 Posted September 14, 2011 Author Posted September 14, 2011 Nothing other than a dialog box saying "this scene has encountered an error and will now close" :). The artist using Max 2012 is busy with other things so I haven't been able to try a reinstall of the tools yet using the September release. I use Max 2010 on my workstation so it isn't a huge problem yet.
ivan.cuevas Posted September 17, 2011 Posted September 17, 2011 We have the same problem using the mesh exporter in Max 2012. Our workaround is to move Unigine plugin files out of Max/plugin folder, restart the application, close it, and restore de Unigine plugin files again. The mesh exporter works until next crash, then we have to repeat the same operation. How much people have this problem?
manguste Posted September 23, 2011 Posted September 23, 2011 Can't reproduce it :( On our side export and reexport do not result in a crash. Do you you use the latest version of Tools? And could you provide more detailed info on your OS?
