How to put Unigine Render Window in Qt?
Dear All:
I want put Unigine Render Window in a QWidget,I find sample GLAppQt,but it just put Unigine Render Window in a QGLWidget,it means I have to use Unigine OpenGL Renderer.
Previous,I put Ogre Renderer in QWidget,whatever type of Ogre Renderer.
I want use Unigine DirectX Renderer,I aslo find D3D9AppMFC,I refer it,want put Unigine DirectX Renderer Window in QWidget.
Now,I have a problem,The QWidget have my Unigine Render Window,but it is just show the Qt background,it can't show Unigine Render Result,just like a empty QWidget.but the Unigine is updating.
Who can tell me how to put Unigine Render Window in Qt?
Thank you very much,forget my poor English.
I did it.
All C++ source code.
I found the Engine::update(),swap(),render() is very very different App::update(),swap(),render();
The GLAppQt and D3D9AppMFC just write:
App::update();
App::render();
App::swap();
It is did not work.
I have to write this:
Engine::update();
//Engine::render();
Engine::swap();
App::update();
App::render();
App::swap();
and it is render now.
iSpinel.
Pay attention:
Engine::render(); please do NOT use when Unigine in a QWidget.
when I use Engine::render() and App::render(), the QWidget is very vague.
when I just use Engine::render(),it can NOT render anything in QWidget.
The Engine::update,render,swap and App::update,render,swap is so let me confuse.
I don't know why.
why?
I have a new problem,when I use:
QMainWindow->setCentralWidget(pMyUnigineWidget);
The Unigine can not render anything in MyUnigineWidget..
But when I just use pMyUnigineWidget->show(); the Unigine is render in the MyUnigineWidget.
why?
Who can give me a mature Unigine in Qt sample????
Thank you very much.
Our developers will create an application that renders Unigine into QWidget with DirectX renderer.
Qt app should always use App::update() and other App functions, not Engine::update(). Which one to use in the application, Unigine::Engine or Unigine::App, depends on whether the engine has direct control over the main loop or not.
  • Unigine::App class is used when the engine passively waits for the app to cycle through the main loop. This is the case with Qt apps (because they are event-based and wait for the specific QEvent). The same goes for MFC application.
  • Unigine::Engine class is used when the engine cycles through the main loop by itself. This is the case with SDL apps.
You should not call both Unigine::App and Unigine::Engine functions at the same time, because it essentially messes up the main loop.
But I have to use like this:
App::update();
App::render();
App::swap();
Engine::swap();
If don't use"Engine::swap()",it is did NOT render anything.
  • 3 weeks later...
Qt applications with DirectX renderer are ready, check them in the newest SDK :)
