fox Posted October 21, 2022 Posted October 21, 2022 We'd like to thank all of you for your valuable feedback and bug reports helping us get better. This hotfix resolves a number of issues introduced in 2.16. Engine - Fixed an issue with incorrect mouse cursor handling on Astra Linux 1.6 CE (kernel 4.15) and 1.7 SE (kernels 5.4, 5.10, 5.15) - Fixed dynamic reflection artefacts when using a Water Mesh object with Planar Reflections. - Fixed an issue that made Projection Configuration window unavailable in Syncker+Projection applications. - Watermarks in applications built with the evaluation kit are now displayed correctly. Editor and Tools - Fixed a crash on reloading a world in case a node is selected in the Editor Viewport. - Fixed an issue that caused Editor hanging on changing keyboard layout. - Fixed an issue that caused Editor hanging on removing a Landscape Layer Map. - Fixed a crash of the Sandworm tool on removing a data source having a filter added. Samples and Demos - Renamed "IG Aircraft" add-on as "IG Aviation". - Removed deprecated defines that generated error messages in the console when running the plugins/oculus_00 sample. - Updated code of C# components in the Docs Sample Content assets pack.
