carl.sutton Posted October 4, 2011 Posted October 4, 2011 I am currently making use of the node import/export feature and applying a custom properties to my nodes. This seems to be a really powerful feature, but the lack of property parameter types such as vec3 mean I have to store 3 individual floats to store any custom vec3 data. Ideally I want my .prop files to be in the following format: <?xml version="1.0" encoding="utf-8"?> <properties version="1.00"> <property editable="1" name="fold"> <parameter name="offset" type="vec3">0.0 0.0 0.0</parameter> <parameter name="axis" type="vec3">0.0 0.0 0.0</parameter> <parameter name="angle" type="float">0.0</parameter> </property> </properties> I believe it would be of advantage to also include quat, vec4 and mat4 parameter types in a property too, even if they weren't intended to be editable through the editor as this may be more convenient for some.
danni.coy Posted October 4, 2011 Posted October 4, 2011 you could cheat and use ParameterColor (which is a vec4)... for vec3,vec4 and quat classes. If you access the data infrequently you can use a string. But yes I would like this addition to the property system too :)
manguste Posted October 18, 2011 Posted October 18, 2011 Our developers have added vec3 and vec4 support for properties to the to-do list.
frustum Posted October 27, 2011 Posted October 27, 2011 I think it's quite difficult to edit 16 components of matrix directly. In Unigine script you can easily convert string to matrix and vice versa: mat4(getParameterString(id)) setParameterString(string(mat4_identity));
danni.coy Posted October 27, 2011 Posted October 27, 2011 will this make a difference to performance if the parameter is being accessed frequently?
frustum Posted October 27, 2011 Posted October 27, 2011 It depends on access frequency. It's a problem if you have more than hundreds of accesses per frame.
