two bugs in current unigine 2010-09-07
I recently met 2 bugs in unigine,
  1. engine.app.setTitle support utf8 encoded string, that's good, I set the title in world's init function, after that, I switch to another resolusion, the title becomes random string.
  2. can not switch to fullscreen mode, it becomes 2 result, either 640x480, fullscreen, or prompt can not set to 1280x720 fullscreen.
random string app title
the second problem I've seen in this forum.
  • 2 weeks later...
With new UNIGINE release we also encounter fullscreen problems when trying to switch from windowed mode to fullscreen mode. UNIGINE shows "Can't apply settings" mesage box with no further error message and stays in windowed mode.
Problem reproduceable with DX9 and OpenGL on different machines running WindowsXP. Using earlier UNIGINE versions on same machines does not show this problem and switch between windowed/fullscreen flawlessly (so it does not seem to be a driver issue)
There is a bug with fullscreen mode indeed, it's already fixed. We can send hotfix if you're interested.
Hi Denis, yes, of course we are interested :)
