Amerio.Stephane Posted December 11, 2023 Posted December 11, 2023 Hi, The configuration of master+slaves is at startup: master: render_exposure=0.5, render_exposure_mode=2 OTW slaves: render_exposure=1.2, render_exposure_mode=1 Sensor slaves: render_exposure=0.5, render_exposure_mode=2 This setup is made so sensors and master are auto adapting exposure, but the OTW have a fixed exposure calibrated for our environment. The probleme: as soon as a CIGI CelestialControl is received, ALL slaves revert to render_exposure = 0.5, making the OTW very dark (exposure_mode is not changed). Is this expected? How can I avoid this? What is the preferred way if I want OTW to have fixed exposure (with a specific, configurable value), while still having other slaves with an auto exposure? Thanks!
cash-metall Posted December 11, 2023 Posted December 11, 2023 Hello! Syncker synchronizes basic render settings between all machines. Including render_exposure. Unfortunately there is no way to disable synchronization of one parameter - only complete synchronization of render settings via slave->setSkipFlags(Slave::SKIP_FLAGS::RENDER) but it will lead to problems in weather synchronization: render_environment_presets are synchronized in the same block. so in your case I can only suggest workaround: set the exposure in each frame - this function is very cheap and should not affect performance. int AppSystemLogic::postUpdate() { //... if (is_OTW_slave) Render::setExposure(1.2); //... }
Amerio.Stephane Posted December 11, 2023 Author Posted December 11, 2023 Understood, but in this case, it's not clear why render_exposure_mode is not synchronized too, for example. Can we have an exhaustive list of the actually synched parameters please? As a suggestion, just like we have the possibility to select the post effect filter in a view in the xml, it would be great to be able to also set the other render parameters.
cash-metall Posted December 14, 2023 Posted December 14, 2023 Because, in order to optimize the serialization of render settings, we only synchronize frequently changed parameters, assuming that they can change at runtime. Changing the exposure_mode is not expected in every frame, so we do not synchronize it. Moreover, we recommend disabling autoexposure when you are using a multiple-projector system. Here is all render parameters which are synchronized: // distance parameters DistanceScale FieldDistance LightDistance DecalDistance ObjectDistance ShadowDistance ReflectionDistance // stereo parameters StereoDistance StereoRadius StereoOffset // animation parameters AnimationStem AnimationLeaf AnimationScale AnimationWind AnimationTime // environment presets Intensity ScatteringBaseLUTName ScatteringMieLUTName ScatteringLightColorLUTName TextureName TextureColor HazeColor HazeMaxDistance HazeDensity HazePhysicalStartHeight HazePhysicalHalfVisibilityDistance HazePhysicalHalfFalloffHeight HazePhysicalSunLightIntensity HazePhysicalSunColorSaturation EnvironmentHazeMode // SSAO SSAOIntensity // refraction RefractionDispersion // motion blur MotionBlurVelocityScale MotionBlurMaxVelocity // screen-space shadow shafts ScreenSpaceShadowShaftsMode ScreenSpaceShadowShaftsResolution ScreenSpaceShadowShaftsQuality ScreenSpaceShadowShaftsLength // depth of field post-processing DOFFocalDistance DOFChromaticAberration DOFBlur DOFFarDistance DOFFarFocalOffset DOFNearDistance DOFNearFocalOffset // camera effects post-processing CameraEffectsThreshold DirtTextureName DirtScale // exposure post-processing Exposure ExposureAdaptation ExposureMinLuminance ExposureMaxLuminance // filmic post processing FilmicShoulderScale FilmicLinearScale FilmicLinearAngle FilmicToeScale FilmicToeNumerator FilmicToeDenominator FilmicWhiteLevel // cross post processing CrossColor CrossScale CrossShafts CrossLength CrossAngle CrossThreshold // lens post processing LensColor LensScale LensLength LensRadius LensThreshold LensDispersion // color post-processing ColorCorrectionBrightness ColorCorrectionContrast ColorCorrectionGamma ColorCorrectionWhite ColorCorrectionRamp // bloom BloomScale BloomPower // fade post-processing FadeColor // clouds CloudsLightingQuality CloudsLightingTraceLength CloudsLightingConeRadius CloudsDynamicCoverageArea CloudsDynamicCoverageResolution CloudsInterleavedRendering CloudsDownsamplingRendering CloudsSamplingQuality CloudsTransparentOrder 1
cash-metall Posted December 14, 2023 Posted December 14, 2023 Quote As a suggestion, just like we have the possibility to select the post effect filter in a view in the xml, it would be great to be able to also set the other render parameters. I didn't quite understand which render parameters you are referring to. Please tell us more details about task you are trying to solve. We are planning to change our approach to rendering parameter serialization in the near future, so it is important to understand your needs.
Amerio.Stephane Posted December 14, 2023 Author Posted December 14, 2023 Thank you @cash-metall for this thorough listing. In essence, we have a single CIGI host that sends messages to the IG master which then has multiple slaves with different role. the master itself displays view 0 as a spectator view or a 3rd person view of the helicopter, with cinematic effects (glow, lens flares, eye adaptation, etc) the dome slaves displays view 1 as an OTW view, with no cinematic effect, no WB, no lens flares, no eye adaptation, no motion blur, etc the sensors slaves display view 2+ as different sensors, with different effects depending on the sensor (WB, adaption, blur, noise, low resolution, etc) Up until recently, all views had the same settings (ie the OTW settings) except for post-filter; but we recently had a request to had more "realist/cinematic" effect depending on the view type. And the master view is the most viewed one (as it is in the control room) and VIPs love to see cinematic effects :-) To sum up, the current render settings are dispatched among the world definition, the render settings, the view post_filter. It would be great to be able to set all these in a dedicated "RenderFilter" object which could be attached to a view. Hope this makes sense!
cash-metall Posted December 18, 2023 Posted December 18, 2023 Thanks for the explanation! I understood your task. Indeed, it is now impossible to set different Render Settings for different viewports. Looks like a very useful setting. As a temprorary workaround you can do this with other basematerial and UnigineScript inside. File render_test.basemat there is an example of how to change some render settin gs from postmaterial. (but in this case, not all settings can change correctly due to injection into the render) just copy file to data and specify in ig_config <view_type type="1" post_materials="Unigine::post_sensor_heat,render_test"/> 1
