pit Posted October 12, 2011 Posted October 12, 2011 Aplication built with not defined USE_MEMORY macro (standart new operator is used in this case, as I understand) crahes in vec4 copy constructor. Crash happens while performing one of sse instructions. Bug disappeared after removing USE_SSE and USE_SSE2 macro definitions. It is easy to reproduce this bug: simply open unigine_vc2008.vcproj from Unigine distribution, remove USE_MEMORY macro form prepocessor definition and build. Using resulting library will cause application crash.
frustum Posted October 12, 2011 Posted October 12, 2011 It's not a bug. SSE, ALTIVEC and NEON requires strong data alignment which can't be satisfied without internal memory manager.
