dustinm5 Posted August 22, 2024 Posted August 22, 2024 (edited) Noob to Unigine, long time user of Max. Ive went through a video tutorial to double check the correct nodes to use. Just getting a black Albedo for some reason on the floor tile material. You can seethe texture showing in the materials window. So I suspect its nothing wrong with the texture but something in my main scene that Im missing. Im also surprised that some of these utility nodes arent just built in to the main nodes, such as slider. Edited August 22, 2024 by dustinm5
arizmenda Posted August 22, 2024 Posted August 22, 2024 Hi! What SDK version are you currently using? So far the problem is a bit unclear. Will it look better in a more illuminated place? Have you tried applying another material to a floor, is it going to be a same or a bit different? Perhaps, there is something with using that additional roughness texture, but it's hard to say. We could provide more information if we received a sample of the material from you, or even a whole scene, will that be possible? You can export any assets from asset browser by clicking on it with RMB -> Export As Package, and attach it to your message. Thanks!
