Amerio.Stephane Posted April 25, 2025 Posted April 25, 2025 Hi, I have a component with a mask parameter defined like this: PROP_PARAM(Mask, mask, "intersection", 0xFFFF); I'm trying to control it through CIGI componentControl, so I put this in ig_config: <parameter type="int" name="data3">mask</parameter> But at run time, when sending the corresponding message, the IG warns me with: WARNING: Component::ComponentParameter::setValueInt: type of parameter mask is not Int What is the correct way to do this? Thanks!
cash-metall Posted April 25, 2025 Posted April 25, 2025 Hello! Indeed, the Mask type is not handled when processing the CIGI parameter. This will be fixed in the next release. For now, I can suggest simply using: PROP_PARAM(Int, mask, 0xFFFF); Thank you! 1
