command line option to override ig_config?
I'm pretty sure this exists but can't put my hand on it in the doc:
Is there any way to pass IG/CIGI/DIS options in the command line in the launch script to override any settings in the ig_config.xml?
Hello!
At the moment you can only override the following parameters:
-ig_config "path/to/ig_config.xml"
-cigi_host "127.0.0.1"
-cigi_send_port 8899
-cigi_recv_port 8899
-dis_address "127.255.255.255"
-dis_multicast 1/0
-dis_site_id 11
-dis_exercise_id 22
-dis_app_id 33
-dis_port 3000
Let me know if you need any additional parameters.
  • Like 2
  • 5 months later...
Hi, would it be possible to add something for the default view ID and the default database too?
Hello!
No, there are no such built-in commands. but you can define them by yourself
int getCommandArg(const char *arg_name, int default_value)
	Engine *engine = Engine::get();
	for (int i = 0; i < engine->getNumArgs() - 1; i++)
		const char *name = engine->getArg(i);
		if (name[0] == '-')
			name++;
			if (!strcmp(name, arg_name))
				return engine->getArgi(i + 1);
	return default_value;
int AppSystemLogic::init()
	int default_view = getCommandArg("default_view", ig_manager->getCurrentView());
	// change config value
	ig_manager->getConfig()->setValue("IG.default_view_id", default_view);
	// or directly apply
	ig_manager->setCurrentView(default_view);
	int default_database = getCommandArg("default_database", ig_manager->getCurrentDatabaseID());
	ig_manager->getConfig()->setValue("IG.autoload_database", default_database);
	ig_manager->loadDatabase(default_database);
