Marilou.Grignoli Posted June 13, 2025 Posted June 13, 2025 Hello, When I launch my IG from a master PC on two slaves, I've noticed the environment doesn't load at the same speed on each slave. I've attached screenshots from both slaves, taken shortly after launch, to show this. After that, during a simple flight simulation, the environment sometimes loses all its detail again. The really problematic part is that this doesn't happen at the same time on both slaves, which causes a visible separation between the two screens. What parameters do you think could be most involved in causing this kind of asynchronous loading and detail loss, so I can investigate them further? Thank you for your help, Have a nice day.
bmyagkov Posted June 16, 2025 Posted June 16, 2025 Hello! @Marilou.GrignoliHave you recently started experiencing this issue or has it been present for some time already? Also, just to clarify—when you mention environment, are you referring specifically to the terrain surface details or are other elements in the scene affected as well? If it’s only related to the Landscape Terrain it might be worth checking how different settings influence the behavior. You can try adjusting parameters under Unigine Editor → Settings → Landscape particularly the "Preset" options for Geometry and Streaming. Lastly, could you let us know the specifications of the PC used for testing? Are they all the same or do they differ? Thanks!
Marilou.Grignoli Posted June 17, 2025 Author Posted June 17, 2025 Hello, Thank you for your answer. This has been happening for some time already. I am referring to the terrain surface details, the buildings, and the vegetation. I have attached a picture of my current settings for Landscape. The three PCs are the same (DELL GeForce RTX 4090, with exactly the same display settings, refresh rate is 75Hz for the slaves and 60Hz for the master); however, I just saw that the driver version is 552.44 for one of the slaves, whereas it is 551.23 for the other slave and the master. So I updated all the drivers and tested it again : I saw the same loading difference between the slaves. Have nice day !
bmyagkov Posted June 17, 2025 Posted June 17, 2025 Hello! 56 minutes ago, Marilou.Grignoli said: I am referring to the terrain surface details, the buildings, and the vegetation. So, just to confirm—it's not only the Landscape Terrain that's affected but basically the entire scene including all its objects is loading with some delay? 58 minutes ago, Marilou.Grignoli said: I have attached a picture of my current settings for Landscape. Would it be possible for you to switch from the High preset to Low and see if the behavior changes in any way? Thanks!
Marilou.Grignoli Posted June 17, 2025 Author Posted June 17, 2025 (edited) Hello! As you asked I have changed from High to Low preset, I saw a difference for the right slave which took longer to load but the difference remained : At first : left : right : After 20 seconds we can see the left slave is "late" again : left: right: This time when flying I saw that it was more the terrain and the differneces I saw before in te loading of the buildings and other objects happen at the same time on both slaves. Here is an example of what happens during flight : on the right screen at some point the terrain had to "reload". left: right: Edited June 17, 2025 by Marilou.Grignoli
bmyagkov Posted June 18, 2025 Posted June 18, 2025 Hello! @Marilou.GrignoliThank you for the additional information. We would appreciate it if you could also help clarify the following questions: Which SDK release is being used for this project? Is the SpiderVision plugin utilized in this setup? Are any custom cameras being used on the slave PC instances? What are the exact startup arguments used to launch the slave instances? Thank you in advance for your assistance!
Marilou.Grignoli Posted June 27, 2025 Author Posted June 27, 2025 Hello, Sorry for the late answer. 1) sim_windows_2.19.1.1 2) Yes I use Spider vision for the calibration 3) Yes I have customs cameras, (the pictures above were made in pilot eye point of view) To give you more insights and pieces of my code and as much details as I can, I will open a ticket. Thank you for your help, have a good day ! 1
bmyagkov Posted June 27, 2025 Posted June 27, 2025 Hello! 6 minutes ago, Marilou.Grignoli said: To give you more insights and pieces of my code and as much details as I can, I will open a ticket. Yes, proceeding with the issue through the support ticket form sounds perfect. Thank you in advance!
