[SOLVED] World Expressions at Startup
Hello everyone,
A new Unigine Script question, this time I wonder if I stumbled upon a bug.
I was monitoring performance of World Expression use by microprofiling various expressions using the most common operations (getting a node, getting a parent, toggling a surface...) and I stumbled upon a behavior I didn't not anticipate. My nearly empty project contains 1000 sphere node references. The source node has World Expression children, with only one active at a time (the one I'm profiling).
The last one I added is a toggling surface loop:
    Node parent = getNode().getParent();   // Get the signal parent object
ObjectMeshStatic obj = class_cast("ObjectMeshStatic", parent);
int surf = obj.findSurface("sphere");
    float current_time = frac(engine.game.getTime());
    if(current_time > 0.5f)
        obj.setEnabled(1, surf);
else
    obj.setEnabled(0, surf);
The expression works when active, it's fine. However, when I tried to use one of my other World Expressions by Running the application, I will always find my surface turned off at the beginning. Almost as if this inactive World Expression was executed once at start. If I reopen the editor, I found myself with the same problem: the surfaces are turned off.
So my question is: are World Expressions executed once at startup, even if they are set to inactive in the tree ?
Hello!
This is definitely not intentional behavior — we’ve filed it as a bug in our internal tracker and it will be addressed in a future update :)
For now, you can resolve it by adding the following code at the beginning of your World Expression:
Node node = getNode();
if (!node.isEnabled()) return;
Hope this helps and thanks for reporting it!
Thanks for the fix, that works for me :)
  • bmyagkov changed the title to [SOLVED] World Expressions at Startup
