Editor and C++ component compatibility
I'm trying to adapt our components so they can be more easily configured from inside the editor. I having quite a few successes, but some of the ig_aviation for example plugins are not compatible with this way of doing.
As a matter of fact, the IG plugin is not available inside the Editor, so typically all components that rely on it should first check for this condition before continuing. But as an obvious example, the macro IG_ONLY_FOR_MASTER   is clearly not Editor-proof:
#define IG_ONLY_FOR_MASTER                                 \
    if (!Unigine::Plugins::IG::Manager::get()->isMaster()) \
        return;
This leads to an immediate crash in the Editor, of course. And I suspect more of them have some sort of unforeseen incompatibilities.
To be clear: I can understand that a runtime-only, IG specific plugin, is not meant to work nor be editable/configurable from within the editor (that is a dedicated work in itself), but as it is, they prevent us completely from making any editor-compatible component.
  • Could there be any way to prevent some components to be evaluated in the Editor, while some others keep be evaluated?
  • Could you make some basic pre-conditions test in the problematic components to just bypass the init/update/shutdown of these?
To give more context, we have some components that rely on hard-to-guess float values or that would play some animation when triggered. Without in-editor execution, we have to tweak the values/save/relaunch the app/do it again a few dozen times before getting it right. Tedious.
Side note: We define some Console variables in the cpp of the components, for example to trigger some debug visualizer info. But these variables are not reachable from the Editor console, although the component itself does access them correctly. Is it a bug, or should we doing something specific to have them accessible in the editor?
Hello!
Yes, indeed, the IG_ONLY_FOR_MASTER macro does not check for the presence of the plugin, since it was not intended to be used outside of IG.
You can modify this macro or replace it with your own:
	if (Unigine::Plugins::IG::Manager::get() && !Unigine::Plugins::IG::Manager::get()->isMaster()) \
		return;
In your own components, you can add a macro like this:
#define ONLY_FOR_RUNTIME             \
	if (Unigine::Editor::isLoaded()) \
		return;
to prevent execution inside the Editor.
If you want to completely disable components in the Editor or at runtime, you can add your own registration macros.
#include <UnigineEditor.h>
#define REGISTER_COMPONENT_EDITOR_ONLY(CLASS_NAME)        \
	class ComponentRegistrator_##CLASS_NAME        \
	public:        \
		ComponentRegistrator_##CLASS_NAME()        \
			Unigine::ComponentSystem::get()->addInitCallback(Unigine::MakeCallback(this, &ComponentRegistrator_##CLASS_NAME::register_component)); \
		void register_component()        \
				Unigine::ComponentSystem::get()->registerComponent<CLASS_NAME>();        \
		~ComponentRegistrator_##CLASS_NAME()        \
				Unigine::ComponentSystem::get()->unregisterComponent<CLASS_NAME>();        \
	} __component_registrator_##CLASS_NAME;
#define REGISTER_COMPONENT_RUNTIME_ONLY(CLASS_NAME)        \
	public:        \
			if (!Unigine::Editor::isLoaded())        \
and usage example:
class MyСomponentWorkOnlyInEditor: public Unigine::ComponentBase
	COMPONENT_DEFINE(MyСomponentWorkOnlyInEditor, Unigine::ComponentBase);
	COMPONENT_INIT(init)
	void init()
		Unigine::Log::message("this message only in editor\n");
class MyComponentWorkOnlyInRuntime: public Unigine::ComponentBase
	COMPONENT_DEFINE(MyComponentWorkOnlyInRuntime, Unigine::ComponentBase);
	void init()
		Unigine::Log::message("this message only in runtime\n");
class MyComponentWorkAnyway: public Unigine::ComponentBase
	COMPONENT_DEFINE(MyComponentWorkAnyway, Unigine::ComponentBase);
	void init()
		Unigine::Log::message("this message everywere\n");
REGISTER_COMPONENT(MyComponentWorkAnyway)
REGISTER_COMPONENT_EDITOR_ONLY(MyСomponentWorkOnlyInEditor);
REGISTER_COMPONENT_RUNTIME_ONLY(MyComponentWorkOnlyInRuntime);
Could you clarify which components you're referring to? Are these some of the components from the IG_Aviation_addon that you're trying to run in the Editor?
Indeed, ConsoleVariable*** doesn't work properly in plugins due to initialization order issues with variables declared in the global scope.
At the moment, you can use just Console::addComand:
	Console::addCommand("test_console", "description", MakeCallback([](int argv, char ** argc){
		Log::message("console works!\n");
		for (int i = 0; i < argv; i++)
			Log::message("%d: %s\n", i, argc[i]);
Yes, they are these. In our app, all components are packed in a lib, linked into all our runtime plugins. At the moment, I took the naive, more direct approach of simply also directly linking this same 'component' lib in my editor plugin. As a direct consequence, loading an object in editor which uses one of the ig aviation component immediately crashes.
Hum, I think I'll try going with two libs, one for runtime-only components, and the other for editor-compatible components.
Note: we went with the 'components in lib' way, because we have multiple plugins which all shall access the components. Moreover, if an editor plugin shall also have access, I think this is the only way. Would you have any opinion or advice?
I like the suggestions you made for all the macros, maybe you could use them in a future sdk version directly.
That's what I suspected. Is there any way I could manually 'register' these? Or could I move them from global scope to some other scope? (maybe like the REGISTER_* macro)
A few more questions:
  • I tried running the debug version of the Editor, but it always crashes. Am I missing something?
  • Developing editor compatible components in C++ is currently very risky, as any error in handling data can crash the whole Editor. Would it be possible to consider running these in a separate process, with some kind of proxy to the real Editor process? (not really easy, I guess...)
Hum, same thing with NET_REGISTER_COMPONENT. (just a note to not forget it later)
In our internal projects, we use separate plugins for runtime and the editor. However, we compile the components directly from source into the plugin itself, without using an intermediate library. (I'm just sharing my experience using components in Unigine — this isn't meant to be a reference workflow. )
For example, like this:
This approach allows us to use the same component files but in different way and do tricks like this (Component1.h ):
#include "Manager.h" // This file will be detected in different folders depending on the build configuration.
class MyComponent: public Unigine::ComponentBase
	COMPONENT_DEFINE(MyComponent, Unigine::ComponentBase);
	COMPONENT_UPDATE(update);
	void update()
		//do main logic
		float ifps = Manager::getIFps(); // It will be a different dt depending on the manager that was found.
		node->translate(Unigine::Math::vec3_forward * ifps);
	#ifdef EDITOR_PLUGIN // this block will be compiled only in editor plugin
		COMPONENT_INIT(editor_init)
		COMPONENT_UPDATE(editor_validate,-1);
		void editor_init()
			init_transform = node->getTransform(); // save original transform
			World::getEventPreWorldSave().connect(connections, [this]() { on_world_save(); }); // subscribe on world save callbacks
			World::getEventPreNodeSave().connect(connections, [this]() { on_world_save(); });
		Mat4 init_transform;
		EventConnections connections;
		void on_world_save()
			node->setTransform(init_transform); // restore original transform to avoid save changes in world
		void editor_validate()
			// do some extra check before update editor
	#endif
In other words, we can make certain parts of the code execute only in the Editor, without affecting runtime performance.
As you mentioned, "developing editor-compatible components in C++ is currently very risky", so we try to be extremely cautious — that's why we usually wrap a lot of checks in editor-only defines.
I'm still not sure that using C++ components in the Editor is a good idea. We're waiting for visual scripting)))
no, I'm afraid it won't be possible to find any workaround with it.
can you provide callstack or crashdump? or maybe some way to reproduce it on our side?
yes sure. just replace REGISTER_COMPONENT inside
#define NET_REGISTER_COMPONENT_RUNTIME_ONLY(CLASS_TYPE)                                                \
	class NetworkRegistrator_##CLASS_TYPE                                                              \
	public:        \
		NetworkRegistrator_##CLASS_TYPE()                                                              \
			Unigine::Plugins::IG::NetworkRegistrator::get()->registrateNetworkComponent<CLASS_TYPE>(); \
	} __network_registrator_##CLASS_TYPE;
for _Editor_only you can use REGISTER_COMPONENT_EDITOR_ONLY cause NetworkRegistator is usless in editor
  • Thanks 1
Just for the record: this last code snippet didn't work as is. I had to used a delayed registration, like you did for the regular component:
	public:        \
			Unigine::ComponentSystem::get()->addInitCallback(                                               \
				Unigine::MakeCallback(this, &NetworkRegistrator_##CLASS_TYPE::register_component));         \
Otherwise, it would crash during the global variables init phase, because the Editor singleton would be created after and Editor::isLoaded() would segfault.
As you said, visual scripting could help speed up dev, here :)
