Current GUI vs. MainWindow
What's the difference between adding a widget to GUI.GetCurrent().addChild() vs. using WindowManager.MainWindow.addChild()?
Hello!
If you are working specifically with windows, then you need to use EngineWindowViewport::addChild().  Gui::getCurrent() is kept for compatibility. This method returns the GUI of the window currently being worked on (either updating or rendering). The window manager loops through the windows and updates the current engine.gui at each step.
Additionally, getCurrent() can return engine.default_gui when there are no windows at all.
22 hours ago, silent said:
Hello!
Thank you for the explanation.
I think there is a mistake in the code samples for UserInterface documentation: https://developer.unigine.com/en/docs/2.20/api/library/gui/class.userinterface?rlang=cs#intro  Scroll down to WidgetLifetimeWorld.cs and WidgetLifetimeEngine.cs. Both scripts have Init() and Update() methods twice in the class.
  • Thanks 1
