2.20 mount points
In 2.20, the mount points seems to ignore our "ignore_filters" in the umount file. As shown below, the ".plastic" folder is shown while it should be ignored.
image.png.e0817fa79f513dedf78056367cf06aab.pngshared_AH_XR_MATERIALS.umount
Is this a regression, or did the file change in some other way, or something else?
Also, there is a new section we found in the root umount: "guidsdb_ignore_filters", and the doc is a bit light about it.
Should we add this also to our own umount files (as I did), or is it only needed in the root umount file?
Hi Stephane,
Please try to add ending slash for folders in the ignore list. Something like that:
  • .plastic/
  • .svn/
Quote
This used to specify which files and folders to ignore in guids.db file. If you have a lot of custom data and you don't want to clutter the guids.db you can use it to filter these files out. You can also do it via API.
  • Thanks 1
