Migration of Unigine Scripts to 2.19.1
I have started the process of mgirating our codebase to Unigine 2.19.1. While the documentation is helpful for C++ API, I wonder about the Unigine Script API.
Are the Unigine Script API and the C++ identical ?
I have something like 60k lines of Unigine Script. Right now the advised method internally is to launch the editor, open our worlds and see what crashes. Is there any way to efficiently check the migration changes in the Unigine Scripts ? I haven't seen the upgrade scripts modify our unigine scripts.
PS: It's from 2.18 to 2.19.1, for now.
Thanks in advance
Edited by K.Wagrez
Hi Kevin,
Quote
There is no migration scripts that affects the user code changes (neither C++ / C# or USC).
Quote
I think that's the only available option you have with USC. You run world, check the errors, do the world_reload command after fixing and so on.
Quote
At least that was our goal at the first place, naming should match between the two languages (in the majority of cases).
