Broken GUID links through umount
Hello everyone,
I have a problem that may come from my lack of understanding of the filesystem and the Engine's use of GUIDs. I have an empty folder (with just configs, the ung files), with a folder assets, containing only 2 umount files. These mount poitns are not read only, and have no filters.
image.png.9e6da128f24e220fe09f82c9bc5f2c24.png image.png.3d78ffef88f0333d8dd0643b6a4a1987.png
The default asset folder contains many assets, with their meta files. And maybe ond or two guids.db file. There should be no conflict with the IDs from the project folder. The project asset folder contains a whole hierarchy:
The world is where I work. It was created in another isntance of Unigine, which behaves a little differently, but outputs meta files and a guids.db which contains all the assets in this project folder (I checked).
When I run Unigine on the "empty" project folder (with the umounts), and open this world, the links to the assets are broken. The guids are correct, they are in the guids.db folder in the umount. But it's as if Unigine doesn't read the guids.db file in my umount.
What did I miss ?
Thanks in advance !
Hi Kevin,
As far as I know, the engine should be able to read guids.db files from multiple mounts.
Without seeing the actual content, error messages, and mount files, it’s difficult to determine the exact cause. If you could share them with me (a private link is fine), it would be much easier to investigate.
There might also be a conflict if you have an 'assets' folder both in the default location and inside the mounts, but that’s just a theory for now.
Thank you!
I tried on the side to setup two projects, one loading the assets of the other with a mount point, and it worked. I can't really send the assets I have, for it's actually a mess. Can duplicate GUIDs (the missing guids I'm looking for are not duplicate, but a lot are) cause problems in the mount points ?
Also I have often this kind of message: Asset is invalid and can't be reimported because it is located inside a read-only mount point
But these assets (textures mostly) are supposed to be valid, I litteraly loaded them in editor elsewhere. Is it because the editor might want to patch the runtime guid ? (Since I uppose it doesn't mount the runtimes folder)
Actually the assets with the missing guids are landscape terrains that were generated in a runtime tool, by code. And I'm trying to load it from the editor. Could it cause problems ?
I'm not sure if I'm going to spend more time on this, since this clearly is a problem due to the weird use case/architecture of assets. But I really wish I could debug the whole GUID finding process right now :p
Hi Kevin,
Quote
Yes, duplicated GUIDs can definitely cause issues.
Please, correct me if I wrong, but looks like there are 2 independent issues(?):
  1. Error messages displaying for all(?) textures that are being mounted from the external directory? But the textures itself are displaying in the world?
  2. lmaps are not being displayed after mounting?
The first issue (textures) may occur if there is a mismatch in the .meta files, especially when different engine versions are involved. It’s difficult to say for sure without reviewing the actual content (or at least the .meta files, engine log with errors, and .umount files). There could be another reason as well, but without that information it’s hard to provide an exact explanation.
The second issue may also be related to an incorrect .meta file generated for the lightmaps. Again, we would be able to provide more clarity after reviewing at least the engine log along with the relevant .meta and .umount files.
I also don’t see the root_mount.umount file in the default (empty) folder where you are trying to mount the external content. This file should normally be placed in the data directory, and its absence might also be affecting the current behavior.
  • 4 months later...
Okay, let's discuss umount and guids by themselves, because I need to understand some things.
We have a runtime app that can generate Unigine content (terrain and meshes). It is launched in the context of a "data" folder and has a "guids.db" file, which references accurately the assets generated (a few layermaps and a mesh). These elements don't have meta files.
I made a script that copies all relevant asset folders (and a world) and moves them to a project folder. It also merges the project's guids with the one made by the app, correctly removing some intermediary folders, so as to make the link guid => path correct.
I open Unigine editor on this project, and open the world. I correctly see my terrain and meshes.
However, when selecting terrain/assets, Unigine tells me the asset is missing (by indicating the asset in red), despite the fact that it shows very clearly the asset ! It also creates meta files for all these assets, with a guid different from what's recorded in the guids.db !
Is it an expected behavior ? Is it expected to be able to mix content created and registered under a runtime app, and editor projects ?
Hi Kevin,
Could you please share a portion of your content after the script has been executed (including guids.db, source, meta, runtimes, and runtimes meta files) so we can better understand what is happening?
If possible, it would also be very helpful to receive the same content in its original, unmodified state (before running the script) for comparison. A conversion script would be also nice to check, maybe we can do it with our own content to verify if we have similar behavior.
At the moment, we do not have enough information to clearly understand the exact behavior you are observing.
Thank you!
I can't share the whole project, and it's just a simple process. I will show you how it looks like.
Our runtime app is launched on this folder:
with a guids.db that points to some terrain layers and a track mesh (assets generated and saved in runtime).
guids_runtimeapp.db
I created a new Unigine project from scratch:
with a guids like this:
guids_editorapp.db
My goal was to import the work done in the runtime app in a editor project. Copying the world and the assets inside the editor project. Since meta files are nonexistent, I had the idea of patching the guids files together, with this script:merge_guids.py
When necessary, I removed the /data/ from the paths with another script, to make sure the paths are correct.
So the resulting guids.db is this: guids.db
At this point, after copying my assets from the runtime fodler to the editor fodler and using the merged guids, I open the project and I open the imported world:
My asset links are correct. However I look at the terrain layers, and they show me this:
And the editor has generated a new meta file for the asset this terrain layer points too:
terrain_x37_y1318.lmap.meta
With a different guid than mine. And look at the guids.db now:
guids.db. We see two guids, for essentially the same asset.
Can we generate meta files by hand ? Is there an optino to use the guids.db to generate those files ?
Edited by K.Wagrez
Hello Kevin,
You were so close to make it working.
In the resulting guids.db I see the next record:
"0f9a8b72a3f6eb4981291c376b54ec1760b7212b": "/layer_maps/terrain_x38_y1319.lmap",
It means you removed `/data` instead of removing `/data/` and you should put such a line instead of the previous one:
"0f9a8b72a3f6eb4981291c376b54ec1760b7212b": "layer_maps/terrain_x38_y1319.lmap",
If you correct all new lines like this everything will work fine. I have checked it on my side.
UnigineEditor considers this path as an absolute path and can't find it, UnigineEngine works in a little different way. We will think to make one consistent approach for this case.
  • Thanks 1
Ah thank you @victor, it works now.
Such a tiny little detail !
