[SOLVED] Shoreline fading?
Is there any way to have the water shoreline fx fading in the distance, instead of brutally being cut off?
How can we change the distance of visibility/fading for this cut off?
Edited by Amerio.Stephane
add image
Hello Stéphane,
When working with ObjectWaterGlobal the FieldShoreline is rendered on its surface and requires a high-density wireframe to display correctly. At greater distances tessellation increases triangle sizes which can prevent the FieldShoreline from rendering as intended.
In most cases, setting the Geometry preset for ObjectWaterGlobal to Ultra in the global settings should fully resolve this issue. If the default preset is not sufficient, you may want to switch to a Custom preset for geometry and adjust the geometry progression and polygon size according to your specific needs.
Please take a look at the attached video demonstrating a possible solution.
Oh okay, it wasn't directly apparent that the visibility of shoreline was linked to the water tessellation in the doc (or maybe I missed it). So we'll have to increase that...
  • silent changed the title to [SOLVED] Shoreline fading?
