Jelrak.Vance Posted February 27 Posted February 27 I am building a 3D space fleet game using Unigine version 2.20.0.1. Assuming no editor, what is the correct way to select a spawned node via mouse (left click) and then send it towards a destination within 3D space (right click)? I believe I have to create a component that marks the item as moveable and then assign it to the node. I have created components before, but not one that specifically indicates an item is selectable/moveable. Is there any special command to use here? And given that I am not working with meshes, but node references to DAE files, how do I mark them as dynamic so they can be moveable? Confirmation on how this component should be worded and assigned to the given node would be helpful. What I need to do is: Be able to left-click and/or left-click drag a node (or a box around a series of nodes) spawned from DAE files (I am currently using a node reference to point to the original DAE, but am unsure if there is a more direct way to convert this to a mesh or if that even needs to happen) Have a selection box surround the chosen item(s) Be able to right click somewhere in 3D space (optionally holding the shift key in order to direct along the Z axis) and send the ships to that location with a further left click Here is an illustration of the behavior I am desiring: Any assistance would be greatly appreciated!
