Moon is being erased when changing preset
Hello everyone,
We are currently testing approaches to improve our day/night cycle, and we are testing swapping environment presets to do so. With a few tweaks to camera exposure and render presets, I can obtain some relatively satisfying night ambient sky (I mean, it's an improvement compared to what we had, I'm stil unhappy).
We use our preset2 during the night, and I realized that the moon just... fades.
With preset0. It is actually already faded, not sure why. It's not as faded while high in the sky, but that's still unrealistic:
With preset2 (our night preset). Apart from some obvious artifacts, the clear problem is that the moon is just missing:
Here is the render_settings (which is originally a copy of a new project's ultra settings) I'm playing with.
environment_preset_test.render
My question is: how do I keep having my moon visible while using this "night" preset ?
Am I using it wrong ? Do you have any sample that present a night environment ? Or how to use Unigine to render a convincing night ?
Hi Kevin,
In some our projects we use a simplified approach to day-night cycle and moving sun and moon via tracker (not using any Environment presets except the #1). In attachment you can find such an example. You need to load sun_rotation.track in tracker in order to see it.
Please keep in mind that rotation numbers are pure fiction, so the moon position can be quite strange there 🙂
Also the moon lightning intensity and visible moon billboard intensity are two separate parameters, so if you don't see the moon billboard increase it's scale in Windows -> Settings -> Render -> Environment -> Celestial Bodies -> Moon Intensity:
There can be quite extreme numbers, depending on the exact value being set in the light node.
Thank you!
day-night-simple.upackage
Yes well we had that before, however we could not obtain a satisfying ambient lighting for the night, it was too dark, unrealistic.
We believed your preset system was made to do that kind of things, and we used the preset2 as a way to have a better lighting during the night, especially in urban scenario where the city "pollutes" the sky with the city lights.
With preset0:
With preset2:
I suppose the change from both presets is not just a story of parameters, but the textures used by the presets.
We rather keep preset2 without a moon, than changing it back to preset0.
In order to get back moon to the preset2 you need to replace Light Color texture:
By default it's black (meaning no light emits). If you just copy the texture from Preset 0 to Preset 2 you will get the moon billboard to draw again:
