Guest shane.ploenges Posted November 3, 2011 Posted November 3, 2011 Hi, i was wondering if it is possible to apply a density map to the terrain tesselation material like it is for the mesh tesselation material? It seems the tesselation covers the whole terrain, but it would be great if the tesselation areas of the terrain could be controlled in the same way as the mesh material (with a density map) I found nothing in the documentation about this, is this because it is not currently an option? Thanks in advance
ulf.schroeter Posted November 4, 2011 Posted November 4, 2011 As far as I know tesselation for ObjectTerrain is only used to 'smooth' terrain surface based on basic height map grid points. Terrain tesselation density is/should be an automatic function of adjacent grid point height differences. Therefore - most probably - an additional density map wouldn't provide a real benefit...
manguste Posted November 17, 2011 Posted November 17, 2011 Ulf is right and there's no density map for terrain in its current implementation.
