[SOLVED] Screen space effects and Tone mapper
We are using our IG with multiple adjacent slaves, without any blending between adjacent images (direct-LED walls). I was careful enough to disable all effects that could impact differently the channels (screen space based effects), but the end result is it also disable the tone mapper, giving a final very dull image.
If I don't disable ScreenSpaceEffects (while still disabling bloom, white balance, dynamic exposure, environment haze, vignette, sss), then a seem is sometimes very visible between channels:
(left and right part of the image are from different PC channels).
Increasing BorderX & BorderY does not change the seam appearance.
Again, if I disable ScreenSpaceEffects, then the seam disappear, but the image is too dull because it also disable the tone mapper.
Is there a way to keep the tone mapper enabled? Would there be any other screen space based effect I forgot to disable?
Hi Stephane,
Probably some other screen-space effects are still enabled. Try to disable these as well:
  • render_environment_haze_screen_space_global_illumination 0
  • render_white_balance 0
If this will not produce better results could you please send us your current render settings (either as a preset or cut and paste from .world file)?
Yeah found it, it was SSR and DirtScale. I'm still probably missing a few others (that's why I wanted to simply use render_screen_space_effects).
My initial point holds, though. The toggle render_screen_space_effects shouldn't toggle the global tonemapper in my opinion, because as I understand it the tonemapper effect is just a LUT, so two different PC with adjacent images should always result in a coherent image (unlike the LOCAL tonemapper, which I agree have to be disabled because it IS a screen space effect)
Hi Stephane,
While technically it's correct (although you can in theory have a situation when you have different tonemapper settings set), command behavior will not be changed.
Maybe some new command is required for that specific task (to configure screen-space effects for multi-window / multi-viewport configurations), we don't know yet 🙂
Anyways, thank you for the feedback!
  • silent changed the title to [SOLVED] Screen space effects and Tone mapper
